- 28 Dec 2009
- Wales
Anyone having an issue with wireless fast charge on the beta?
Material Dark (Android 7+) was the theme name I'd been using the longest from the Samsung theme store, maybe that one?
No issues here on beta.
Are you using the Samsung wall adapter? If so, then the wireless charger could be dying. I've had two Samsung ones die the same way.
Use AMOLED Photo.
Photo will dynamically adjust the white balance to account for the ambient lighting based on the rgb light sensor readings. It should technically be more accurate. Adaptive is always more saturated by nature. Photo will look weird at first, but give it a bit to monitor and adjust and it will look really neutral and accurate.
Adaptive is auto adjusting too, but it's a bit pointless given that it's oversaturated anyway if all you want is neutral colour balance. Photo is the closes to AdobeRGB.
Use AMOLED Photo.
Adaptive adjusts the screen for the content being displayed along with the rgb sensor readings base don ambient lightyeah, AMOLED Photo does the same thing just without the over-saturation, and adjusts to be in-line with 98% of the AdobeRGB gamut as opposed to Adaptive's sRGB focus. Basic mode is the closest to sRGB, so better suited to the majority of content, but it does look "dull" in general.
The links were posted on the r/galaxys8 subreddit some months back where the readings were measured. Displaymate did their initial tests but another place went into further detail.
