Nope, cooler keeps things around but mostly below the 60 degree mark
Not bad for £269 with zero hassle/overclocking involved.
Thats nowt, my CPU runs at 59c and cost ~£19
Err, yes it wouldThe 8700K wouldn't get past about 3.8Ghz on a stock Intel cooler, if it'll even get that high after a proper warmup, that wouldn't look good on performance charts. which is the whole point, it makes reviewers use their own and they almost universally use enthusiast grade cooling.
Err, yes it would![]()
Intel's stock cooler is rated for ~65 watts, the 8700K has a TDP of 95 watts and with Anands testing uses about 90 watts of power at stock.
So at stock the 8700K uses about 40% more power than an Intel stock cooler can handle, under a stock cooler it would throttle, a lot, its physics there is no getting away from it, this is why Intel don't ship stock coolers with them
That still doesn't mean with any certainty that it will not go past 3.8 as you state, useless you can link otherwise.Intel's stock cooler is rated for ~65 watts, the 8700K has a TDP of 95 watts and with Anands testing uses about 90 watts of power at stock.
So you are saying the non k chips are much higher quality and a better bin? ... because the non k's can do it easily.
3.8 on all cores is at least at if not already above its own 95 watt TPD rating, for that 95 watt rating its 3.7Ghz. Thats why i was so specific in saying Above 3.8, not 3.7, not
So it's all cores now, keep moving those goalposts.
I'm using what you stated. 3.8 can't be passed.I'm using Intel's goalposts, they rate thier TDP based on 3.7Ghz all cores.
I'm using what you stated. 3.8 can't be achieved.
So you keep saying. you say a lot of things, you saying them doesn't automatically make them facts.
But your theory makes no sense.
got a link to the spec sheet of the cooler?Its not a theory its physics, a 65 watt cooler is inadequate for dissipating 90+ watts of heat.
Sure it can, just not indefinitely. Say a CPU idles at 12w and the cooler is just warm there's probably several seconds of thermal capacity. Probably about 12 seconds![]()
That long?![]()
That's fine. As long as people accept that boost clock!=maximum prolonged clock, it's just cheeky marketing. AMD do the same and Ryzen's XFR would have been more misleading than Intel's if the process it is fabbed on was up to scratch![]()
Not sure. It's base clocks that matter when you have design that scales well![]()
When those base clocks are poor it's a moot point.
