- 9 Jun 2011
How will a gtx 1080 stack Vs 2xxx series card will it be as powerful as 2070?
doubt it probably 1080 = 2060 (1160)
It all depends, 20w on a top tier 250w cards is not much in the grand scheme of things but when your memory controller and ram is sucking up 1/3 of the boards TDP like with RX480/RX580 it makes you wonder how much performance is being held back to get inside the typical board TDP's of 250/150/75w.
I thing it be better for AMD to come out with a 5970 type product, ie top quite taking the performance crown but 90-95% of the cutting edge performance on a smaller cheaper to produce chip which much less power consumption.
Its happened in that past when nvidia (NV30/Fermi) or AMD (Rage128/R600/Vega) have come out with big hot power hungry stinkers they had to start from scratch to get back in the "game" so to speak.
They can't meet demand because demand is infinite. There is no point at which miners will be satisfied with the stock they have. They will keep adding more and more cards.Agree, but why can't the manufactures just double/quadruple capacity to meet the demand? It's not as if this trend came out of nowhere, it's been known for years.
Whilst GPU mining is profitable, no amount of increased production will help one bit.
Sold my 980ti before christmas as I was going away on a holiday.If you're willing to wait a couple of months and have an old card knocking around then I'd sell your current card to miners the second gibbo allows pre-orders, that's what I'll be doing, the old 6970 will get a workout and hopefully the difference in pricing will be relatively small.
If miners have their way, you won't be seeing any real availability. Volta is a killer when it comes to GPU mining.
https://hothardware.com/news/nvidia-titan-v-volta-ethereum
Unless Nvidia gimps them, these will be snapped up in seconds after someone reveals their hashrates with the most common cryptocurrencies.
What has mining on a Titan V got anything to do with the next tranche of gaming GPUs? TV is on HBM2, next gen of gaming cards is likely to be GDDR5X or GDDR6. We have no idea how Pascal replacement will mine.
Volta is more heavily optimised for compute than Pascal, it has features such as true async compute which allows better utilisation of cores. I'm quite sure that when Volta releases, AMD will no longer be the vendor of choice for miners.
Have a I missed a thread where Volta has been confirmed as the next gaming GPU?
nVidia have confirmed Ampere will be the basis for consumer cards.
Seems some people aren't aware and using the Titan V as some sort of forerunner for the next gaming card.
Volta has true hardware async compute just like GCN.
