- 1 Dec 2015
Just install the first one .
You need to enter power plan - advanced settings - and select the AMD option.
Cool, that's the one ive gotJust install the first one .![]()
Morning Chaps,
I left the PC downloading over night but didn't change any settings!!! It must have gone to sleep!!! What are the best settings to use?
Any luck this evening ?
Enjoy it for a few days - gaming/browsing/apps etc...I'm not going to able do much more tonight but what should be my next step?
Enjoy it ! Can okay around after a bit , but after this restart need to really enjoy the gameplay !
Got it for VR so get yourself some good games and go nuts .
Get the kids involved
did you get the RGB on the board changing ?
Hi Mate,
Been a busy few days so haven't had much time to jump on. I still haven't managed to sync the led strip on the motherboard, its not even selectable in fusion, odd! I can change the gpu no problem.
In the the basic Fusion mention, when you select colour cycle or music or pulse, it changes the other lighting area but the side strip ? Or are you using the advanced option and selecting on each area and tell what lighting effect you want it to have ?
Not sure if forum rep @GIGA-Man has come across this issue before ?
Is it this version of the RGB fusion software you are using?
http://download.gigabyte.eu/FileList/Utility/mb_utility_rgb-fusion_B18.0104.1.zip
Thank you mate, it was offering me an update for the version I had but I uninstalled that and installed your one and all is now working,.
