- 10 May 2004
- Middlesex
They would probably be pres of choice too if I had money. Nice!
I think the audient stuff is really good. I have the iD22. They've just anounced the iD44. The pres are great and so are the converters.
They’re ok but I prefer the SSL Alpha VHD pres. Different price point entirely though.
@Merlin5
Studio one professional crossgrade from any Daw is $168.99 works out at £120 at Audio Deluxe.
If you had of bought Mixbus for $29 you would have qualified....
For the first time I've neared a complete mix and have decided to scrap it and start from scratch (everything to -inf, removal of all plugins). Previously I've hit brick walls and have just tweaked a lot.
It's frustrating, I want to be able to nail it first time every time and and it's a bit crushing when I have to do this. I guess that's what the professionals are for.![]()
It's quite a different sound from the CLA Drums mix. Quite crisp and makes my CLA mix sound muddy to me now. The CLA mix is fatter but softer, whereas this mix is brighter, more focused and more detailed. Snare has more of a crack and woody tone now and more presence.
Studio one artist works with VTS3 then ? Did you buy the add On?
I just mixed using default Studio One Artist 3 plugins. Nope I didn't buy the add on and I don't know anything about VTS3.To be honest, it's so difficult recording here because of available time and neighbours that my home recording projects are going to be so rare, I can happily make do with what I have now without buying anything else. Sometime in the future things may change.
I meant VST3....Thought you used the CLA Drums plugin?
Ah yeah, I used the CLA Drums plugin, but with Reaper. I had recorded in Studio One but then I imported the stems into Reaper so I could use the CLA.
Cool...I've been playing with studio one...a bit more and the mix tool to check phase with my drums and room mics as been great....one of my room mics was out of phase and I was losing bottom end on the drums when I blended the room mic in...
I watched this video to learn more...
I soon got the bottom end back on my toms when I inverted the phase on the room mic
@Merlin5 well worth a watch...there is an auto feature in mixbus fir a his but I learnt a lot about my room mics with this video.
Thanks easyrider, I'm gonna watch that later. I didn't know how to check phase so this will help. I did however use the phase switch that's built into the CLA plugin. To be honest though, I wasn't able to tell
which way was right or wrong, both ways sounded fine to me. I made sure my overheads were equidistant from the snare and also the kick drum in a recorderman placement so I'm assuming phase would have been ok.
I had a pair of those PZMs with the same XLR connectors! Good mics but threw them away a few months ago because unfortunately I hadn't looked after them properly and they broke.
