Players, as with the last patch, a new type of anti-cheat solution, which is still under development, is to be applied on the test servers. We are in a test phase with this solution, and its stability and compatibility need to be verified. We would like to collect data about potential compatibility issues, analyze it and solve any issues that may emerge.
If you experience a crash, please take a screenshot that shows the error and report it here. If the current test build is consistently crashing for you, we recommend that you play on the live servers instead. Thank you for your understanding.
Please find the patch notes below:
World
Miramar improvements
- Added more buildings and cover across the map to improve the engagement experience
- Added more off-road routes for easier vehicle navigation
- Upgraded the item spawn level of certain areas for loot balancing (some areas will spawn better loot)
Replay
The replay system has now been updated to a newer version and past replay files cannot be played anymore
Bug fixes
- Fixed the issue where heal and boost items could be used underwater
- Fixed the issue where characters would get stuck in certain areas on Miramar
- Fixed the issue where wall textures on some Miramar buildings were not displaying correctly
- Fixed the issue where certain buildings near by Hacienda del Patron were not displaying correctly
Thank you.
The PUBG Development and Community Team
