- 11 Jan 2007
- *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
I couldn't see a thread yet. I'm due an upgrade soon and I expect I'll go for a Samsung again. Not seen one yet but the rumours sound good, the usual couple of models. It's being unveiled 25th of feb in an unpacked event. Camera improvements is all I have seen so far.
Samsung Galaxy S9 Specs
- OS: Android 8 (Oreo)
- Display: 5.8-inch Quad HD + Curved Super AMOLED, 18.5:9 (570ppi)
- Body: 147.7mm x 68.7mm x 8.5mm, 163g, IP68
- Rear Camera: Super Speed Dual Pixel 12MP AF sensor with OIS (F1.5/F2.4)
- Front Camera: 8MP AF (F1.7)
- Application Processor: 10nm, 64-bit, Octa-core processor (2.8 GHz Quad + 1.7 GHz Quad)
- Memory: 4GB RAM / 64GB + Micro SD Slot (up to 400 GB)
- Battery: 3,000mAh
- Charging: Fast Wired Charging compatible with QC 2.0 / Fast Wireless Charging compatible with WPC and PMA
- Network: Enhanced 4X4 MIMO / CA, LAA, LTE Cat.18
- Connectivity: Wi-Fi 802.11 a/b/g/n/ac (2.4/5GHz), VHT80 MU-MIMO, 1024QAM, Bluetooth® v 5.0 (LE up to 2Mbps), ANT+, USB type-C, NFC, Location (GPS, Galileo, Glonass, BeiDou)
- Payment: NFC, MST
- Sensors: Iris sensor, Pressure sensor, Accelerometer, Barometer, Fingerprint sensor, Gyro sensor, Geomagnetic sensor, Hall sensor, HR sensor, Proximity sensor, RGB Light sensor
- Authentication: Lock type: pattern, PIN, password
- Biometric lock type: iris scanner, fingerprint scanner, face recognition
- Intelligent Scan: biometric authentication with iris scanning and facial recognition
- Audio: Stereo speakers tuned by AKG, Dolby Atmos enabled surround sound
- Audio playback format: MP3, M4A, 3GA, AAC, OGG, OGA, WAV, WMA, AMR, AWB, FLAC, MID, MIDI, XMF, MXMF, IMY, RTTTL, RTX, OTA, APE, DSF, DFF
- Video: MP4, M4V, 3GP, 3G2, WMV, ASF, AVI, FLV, MKV, WEBM
- Virtual Reality: Gear VR with Controller (SM-R325NZVAXAR), Google Daydream View
- Display: 6.2-inch Quad HD + Curved Super AMOLED, 18.5:9 (529ppi)
- Body: 158.1mm x 73.8mm x 8.5mm, 189g, IP68
- Rear Camera: Dual Camera with Dual OIS / Wide-angle: Super Speed Dual Pixel 12MP AF sensor (F1.5/F2.4), Telephoto: 12MP AF sensor (F2.4)
- Memory: 6GB RAM / 64GB + Micro SD Slot (up to 400 GB)
- Battery: 3,500mAh
- Payment: NFC, MST
