Hi Guys.. tempted to pick this up (Hopefully there are some cheap deals around). I know I'm very late to the game![]()
Currently 50% off at humble bundle
I thought it was fairly straightforward.
Picked up one of the Thrustmaster T-16000m For £25 as an introduction to Sticks, for that price I thought it was worth a punt. If I start playing ED more I'll invest in the throttle as well.
Running out of room on my desk though, it's got to sit beside my G29, shifter and keyboard!
any good configs to use with the 16000m?
Was just thinking the same thing about the 3D map.It's a very good showcase for VR, throw in a hotas setup at the same time and it's immersion heaven. Only negative, I found the galaxy map mostly unusable though I suspect that is more keybinding being my issue.
I wasn't sure which option it was but its something to do with 3D mouse hardware rendering? It seemed to be able to allow clicks in 3D with reasonable accuracy and minimal frustration.... this was actually one of the reasons why I was using the monitor more.... but now I will go back to VR![]()
You don't realise just how FRIKKIN' HUGE some of these ships really are until you play in VR!!This is supposed to amazing in VR right?
I would fill the smallest slot you can with a cargo bay, just so you can accept missions with physical rewards. I had just 8 slots on my Python when I used it but it were enough to enable those missions.
