- 19 May 2005
Same hereWhen looking at my version of play services i am showing 11.9.76 - but there are no updates available? :/ confusing
Wired: "Your Google Pixel 2 camera just got even better---here's why".
More third parties are starting to use the Google API to incorporate the advantages of the Visual Core chipset in the Pixel 2.
http://www.wired.co.uk/article/google-pixel-2-camera-visual-core
Just put a Peel Super Thin Case on the MM if anyone is interested
Gents I'm thinking of picking up one of these but it might be second hand, how does the warranty work with Google as I'd purchased direct before and always use their portal to raise a fault
Thanks
OK I don't mind if they do a like for like exchange, refund might be an issue thoughI
I was given a pixel by my sister, Google let me deal with the warranty when the camera went wrong.
They weren't able to replace it with a pixel though, only a pixel XL (which I didn't want). They could only issue a refund to my sister.
Didn't they ask for a copy of the invoice/receipt?I
Have you contacted Google about this charging issue? I certainly couldn't live with that.Still really impressed with the camera. Noticed that depth perception doesn't work well with reflective surfaces however, which is understandable.
Charging is becoming really bad - had my phone on charge for half an hour the other morning, after I'd forgotten to charge it overnight, and it didn't go up at all. And started discharging straight away.
