I was hoping for more from the graphics really. I wonder how much Vega suffers going from HBM2 to DDR4?
Words fail me
thanks for letting us know...Words fail me![]()
thanks for letting us know...![]()
Boot Kit Solution
AMD will provide affected and qualified users a boot kit to perform the BIOS update on their motherboard.
This solution is offered through AMD warranty services and is available only for affected and qualified users of this specific boot up issue. This boot kit is free of charge.
To obtain the boot kit, please carefully follow these instructions:
NOTE: The product must be a valid AMD processor with authentic OPN and serial number.
- Go to the AMD online warranty claims page: https://support.amd.com/en-us/warranty/rma
- Fill in your full contact and product details
- In the Problem Description field enter "Boot kit Required" (without quotes)
I'm not saying it's bad, I was just hoping it might be able to game at 1080p.He's got a point.
The best ever IGP is on a budget/mainstream chip (which has been brute forced into becoming quad cores) and can do 1080p on low graphics while using 65W.
No one else is making an effort to push out a competent all-round chip and it's still at a budget/mainstream price.
So if you say you expected more... it sounds as if you're from another planet.
In the graphics card sub-forum the hype around Vega was huge (interestingly in these threads they also say that nobody cares about power usage), so I was hoping we might see 1080p gaming. It's also why I asked about how much difference DDR4 would make over HBM2 as HBM2 was also hyped quite a lot. Even decent DDR4 is going to be worse than GDDR5/GDR5X isn't it?
Is 65W a limiting factor? Could they have made a 95W chip to give it extra grunt (even if this meant including the Wraith Spire cooler instead)?
Does the 4MB of L3 cache make much of a difference? If i recall, the main difference (other than default clockspeed) between the 1400 and 1500X was that the 1400 had 8MB of L3 cache while the 1500X had 16MB. I believe there were some concerns then about the impact of the lack of cache? Or am I confusing cache levels?
For now I think I'll stick with my Ryzen 5 1400 and GTX 980 combo for my LAN gaming PC. it'd be nice if one day soon-ish I could just use an APU for that.
E-Sports games are often undemanding but yes, there are definitely a number of games that will play comfortably on these chips at 1080p.
Just to be clear, are all of those benchmarks at 1:1 scaling? I know the fact that lots of games now feature their own weird resolution scaling muddies the waters somewhat. I'm not even sure why they bother, unless it's to prevent the OS from having to change resolutions when alt-tabbing or something?
Why?
I have no idea if that's even possible. Theadripper dies are larger, surely?
Oh hang on Googlay....
Overwatch: 1080P 60 to 80 FPS
https://youtu.be/7gSrGlax2JM?t=8m30s
Fortnite: 1080P 60 to 90 FPS.
https://youtu.be/T9WiseBU9sI?t=6m29s
Call of Duty WWII: 1080P 50 to 80 FPS
https://youtu.be/Rp8o48LVZyo?t=8m27s
Battlefield 1: 1080P 40 to 60 FPS
https://youtu.be/K0cxIRp8Q0g?t=7m25s
Quake Champions: 1080P 70 to 90 FPS
https://youtu.be/lhbKfBgOKlA?t=3m1s
PUPG: 1080P 35 to 50 FPS
https://youtu.be/_NuZG5_sdsU?t=6m39s
Assassin’s Creed Origins: 1080P 25 FPS
https://youtu.be/omR9FGTSpLI?t=7m25s
7 games and 5 of them 60Hz+ @ 1080P, only one unplayable.
All E-Sports type games run 1080P 60Hz easily, they also do on the £90 2200G, they really do performance like GT 1030 discrete GPU's or better, those are £65 GPUs on their own.
Ryzen 5 2400G
http://www.tomshardware.com/reviews/amd-ryzen-5-2400g-zen-vega-cpu-gpu,5467.html#xtor=RSS-100
https://www.techpowerup.com/reviews/AMD/Ryzen_5_2400G_Vega_11/
https://www.guru3d.com/articles-pages/amd-ryzen-5-2400g-review,1.html
https://www.extremetech.com/computi...best-blend-cpu-gpu-performance-weve-ever-seen
https://www.pcgamesn.com/amd-ryzen-5-2400g-review-benchmarks
I was looking at the benchmarks in these reviews:
They seem to tell a different story.
They seem to tell a different story.Ryzen 5 2400G
AMD will provide a Boot Kit Solution if your motherboard needs a BIOS update for 2nd Generation Ryzen processors
https://support.amd.com/en-us/kb-articles/Pages/2Gen-Ryzen-AM4-System-Bootup.aspx
I'm guessing a "boot kit" is a loan low-spec CPU that you can use to update the BIOS?
Potential old BIOS issues is what put me off being a early adopter. I don't have any other AM4 CPUs or access to any. Probably best to wait a couple of months while they get the bugs out. At least AMD have jumped on it within a couple of days.
