- 19 Oct 2002
- Shakespeare’s County
There is no additional room, infact I am fairly sure the 5 Series touring has more load space than the X5.
He was talking about kids and dog, the kids go in the back where there is definitely more room. More width across the car, less intrusion from the wheel arch and bolster, More Light from the side glass which is good for motion sickness, More head room and option of a full glass roof. Then the SUV benefit of the driver sits with a higher posture so there’s also more foot room between seat and floor and the tunnel is less instruction.
So yes more room - boot volume is irrelevant.
They are daft anyway as cars with parcel shelves quote up to that where as rollerblinds cargo barriers can quote up to the glass/headliner area behind headrest: plus the whole wet or 1 litre VDA blocks manufactures use to quote brochure figures. Some OEMs with non spare wheel cars even then quote the volume if you were to take the foam under loadboard inserts out!
Haven't been able to drive for 2 days as nowhere had that particular tyre in stock. Should hopefully be back on the road tomorrow...
