@mid_gen how far are you into Odyssey? The game goes up a notch significantly once you defeat bowser.
Yeah it looks a lot nicer than before.
Rocket League has also had a bump looks a lot less jaggy now.
https://www.rocketleague.com/news/rocket-league-roadmap-spring-2018/
- Switch Performance & Visual Quality Updates
- Performance Mode - 900p (Docked) / 720p (Handheld) @ 60 FPS with infrequent dynamic resolution scaling
- Quality Mode - Native 1080p (Docked) / 720p (Handheld) @ 30 FPS with added visual effects
I got a neon switch with Mario kart and Mario Odessey for £260 hardly used.Same here, hunt around for a deal (I think I saw one on Eurogamer earlier). The savings second hand aren't worth the risk imo.
You can go into the settings and check for software updates but if you leave the console docked and sleeping it will do it automatically.How do I check if the console software is up to date?
thanks. Just trying to figure it all outYou can go into the settings and check for software updates but if you leave the console docked and sleeping it will do it automatically.
Digital foundry or whoever does the technical reviews of games has had a look over doom and their general impression is that doom has been improved very slightly graphically but not by much. On the other hand, people who actually play the game for the funs seem to say it has made a big difference.
Not sure if thats a typo Phate but isn't it Puyo Puyo Tetris?
Well I booted Doom up after the update and was showing someone at work and noticed straight away that everything was a lot less muddy looking. DF might be right in their analysis but even to my old eyes it definitely looks to have improved. Gyro aiming is a bit of a game changer too. I used to struggle with it (Splatoon 2), now I look to see if I can enable it off the bat.
BTW I just read a pretty damning review of Payday 2. Lazy port, fugly and too expensive. http://metro.co.uk/2018/02/27/payday-2-switch-review-daylight-robbery-7344518/
Get out.Are you suggesting the devs rather than making real effort for a worthy port were instead just looking to cash in on a quick & easy Payday?![]()
