I'm running it on all high settings and performance is terrible, stutters and goes down to 19fps in places with houses, even on very high it's smooth in anywhere but built areas what's going on.
Can someone throw me a spoiler bone, as I'm stuck pretty much early on.
I've whistled to distract the guys from Thresea, I've gotten on the horse, got hit in the leg with an arrow, but now I can't escape those chasing me, I always end up dead.
Same for me.
Try turning shaders to medium, hardly any difference in image quality but the boost in frames is worth it.
This. You can tell easily by the way your horse's energy bar decreases visibly when galloping.Make sure that you're definitely galloping rather than cantering. Gallop is left shift twice and then held down.
What Gpu?You experiencing smoothness in the wilderness just choppy in towns?
Will try that see how it goes, it's supposed to be smooth at 1440p and and at even very high would expect minimum of 30-40 based on benchmarks, I want to play at 4k on my TV there it should be playable on Very High at least from what I've seen.
Just bought thisLooking forward to playing later on.
Hope to run the game at a respectable 60fps+ on medium settings.
No a freesync so not compatible as have a GTX1080
