- 23 Nov 2014
- The Cronx
I’d recommend it. Just wait for a deal on the eTRVs - i think i paid £120 for 3 inc a hub (which you can then pair with the sockets which are much cheaper than smartthings and work just as well if a bit bigger). Note, very easy to install where you already have normal TRVs but you might need a plumber otherwise. Good luck!
