Electronics running 24/7 at a sustained temperature produce a lot less fatigue on things that are regularly heat cycled with 40-50c swings as that constant contraction/expansion of solder joints etc is what causes them to fail
But that is taken into account and built into the design. Look at how many people are still running 4770K chips overclocked or R290s with no problems for normal usage. GPUs are not designed to run 24/7, hence the large reduction in warranty on official mining cards from the same GPU manufacturers, and warranties being invalidated on gaming cards that are used for mining.
Valid points, and in fairness nothing me or anyone else says will change anyone's opinion on the matter either, one camp will firmly believe mining cards see no extra wear vs gaming cards and vice versa.
Fatigue from heat cycling is a very real issue though. Admittedly it isn't something I've seen for a long time, but there were 10s if not 100s of threads in the 8xxxx, 2xx, 4xx Nvidia era where cards were failing just out of warranty and people were stripping them baking them and getting another 6-12 months life from them (That process is just crudely reflowing the solder fixing any bad joins after all)
I'd gladly buy a card that's been mined on for gaming, and I know exactly the life those cards are getting
I dust in and around mine twice a week.To be fair, I don't know many people who clean their gaming PC regularly, let alone run it in dust free clean room conditions.
If a GPU is run sensibly I see no impact of using it for mining in terms of it's reliability.
I would class mining in any way shape or form as a business and therefore anyone offloading ex mining gear on the MM is trading which is against the rules.
OcUK and these forums has always been about gaming which means a maximum of 4 cards.
I really think OcUK should ban any mining gear being sold in the MM as it is bad for the members (Clapped out cards) and bad for the company.
What kind of person sells a mining card?
I bet you think BitTorrent is an evil technology too.The type that is actively helping parasite money launderers, rogue states, child pornographers, drug pushers, arms dealers and just about every other form of low life hide their illicit profits.
I'm pretty sure I'm not a money laundering, child pornogpraphing, drug dealing, gun weilding terroristThe type that is actively helping parasite money launderers, rogue states, child pornographers, drug pushers, arms dealers and just about every other form of low life hide their illicit profits.
Of course I know what you meant, but you are saying miners are as bad as those peopleRead my post again, because that is not what I said..and you know it.![]()
