- 29 Dec 2004
- Shepley
Funny you should say that, my allergies often flare up on the plane to anywhere mountainous.
Clearance for gobbling cobbles on 28's is a goer
Also, has anyone used Juice Lubes Bearing Grease in their free-hub? Pulled my DT240 apart this evening and it was pretty tidy still but cleaned it up anyway and used some JLBG sparingly as it's pretty thick and viscous.
General consensus is most greases are fine in addition to the DT branded/specified stuff. It's definitely quieter, not that the noise bothered me but I'm wondering if a thicker grease would impede efficient free-wheeling (i.e. reduce coasting distance).
Is that a Madone Benny?
my experience is that the noise rapidly goes back to normal and with it any sense of impedance. It'd be a watt max anyway
I'm indifferent to the noise or any lack of, I could do with a lighter multi-purpose grease just to have on hand. Any recommendations?
Yeah but as time goes on it'll be less likely CRC will give me a 'full refund'. Even now I'm beyond their initial 30 days so the refund will be in CRC 'credit'. Now as they don't stock the Direto (yet!) that's not very helpful... Wiggle stock both, so I'd hope they would eventually mirror stock/suppliers/ranges? Although who knows!
The power issue... My FTP previously (September) was around 275W (Vortex over-reading), along with outside efforts being around the same figure.
I was getting ill around the same time as that last race, but most of those race efforts where pulling hard to place teammates in overall (CVR League) or on climbs to try and keep in lead groups, so fairly constant threshold efforts. I've increased volume and getting back on track (really feeling like I've recovered) but none of my recent race efforts have hit back up to 3.5w/kg, nevermind 3.7-3.8w/kg yet!
- Several of my Vortex 20 minute race effort averages being around 300W (3.7-3.8w/kg at the end of January).
- Switching to the Flux my race efforts dropped to around 260W with my 20 minute race efforts at the start of February around 3.3-3.5w/kg.
I'll need to take a closer look at those links later but I will say that my FTP dropped quite a bit when I got the direto, previously had a Tacx Flow. I put this down to firstly being in the off-season so I'd slacked off a little, but mainly because the direto is much more accurate. The flow was rated around 10% -/+ in accuracy. Last night's test suggested that my devices are probably correct. Yours might be too?
What I'm seeing is the Vortex was over reading slightly, maybe 30-40W over my PWM. Now the Flux seems to be under reading the Vortex by 60-70W, so is under reading my PWM by around 30-40W. Seemingly higher at higher wattages. I can barely hit & hold 500W sprinting on the Flux at max efforts, being able to hit 700-800W on my PWM outside for similar short sprints.Roady - excuse me not going on an in-depth search but what's the complaint with the Flux exactly?
Goes without saying the Vortex over-read by easily 8% (that's my estimate anyway - I saw a drop of at least 8%, maybe even 10% when going from Vortex to 4iiii) and you are aware of that - so if your power remains down (by Vortex standards) by let's say 8% / 10% ish, then what's the issue?
I'm actually taking it as a challenge to get back to my old (Vortex) FTP of 248w, last FTP using my 4iiii was 222w. Make it more fun and less costly by keeping what you've got and just trying harder.![]()
Funny you should say that... Nicely leads into what I was going to post about...I need something to brag about since I can't seem to compete with you lot when it comes to absolute power.![]()
Good clearance! What tyres? Not much tread if the cobbles are wet & dirty!Clearance for gobbling cobbles on 28's is a goer
The finishline light waterproof stuff I got is good, I've used it loads for various things (pedal spindles, freehubs, wheel bearings) but it is white and a bit gunky/gloopy. Great waterproofing though! I use a 'morgan blue aquaproof paste' for thicker stuff, threads and for sealing bearings from the elements.I'm indifferent to the noise or any lack of, I could do with a lighter multi-purpose grease just to have on hand. Any recommendations?
Thanks. I'm pretty much limited to CRC (due to their returns policy) and there's no point returning my Flux (unless it gets worse) until they actually stock the Direto. They won't do a full refund, only 'CRC credit' after 30 days...Haydn, another heads up route for a Direto deal for you...
https://www.topcashback.co.uk/probikekit/ (6% if new customer, 4% if existing)
Go to PBK through TCB site, but for reference, they have Direto on offer at £634.49 with a free towel https://www.probikekit.co.uk/turbo-...art-b-power-meter-turbo-trainer/11526674.html
With 6% TCB, you would effectively pay ~£596.
Bought my Direto through PBK week before Xmas, when they sent me a 15% voucher code, arrived before the festivities.
For those not aware, I popped into Bicester Village yesterday afternoon and there's a Rapha shop now. First time i've seen their kit in the flesh. Good discounts on everything.
Anyone seen the bars on the new Canyon Gravel bike? Very weird.
I live 15~ miles away and drop in for coffee regularly.
Double-decker 'hover' bar. Yes. Weird.
seems almost purpose-designed not to be held in the hooks.
Snap : I feel your pain - I was due to ride an event this weekend too and it's been moved. The MMH on Strava worked out okay thoughI'm starting to get annoyed now.
MMH sportive postponed, so whilst re-arranged date was being decided I booked a B'ham St Marys Hospice mini (75 km) sportive for this Sunday - now that's under threat of beast from the east mark II. FFS what do I have to do to get my bike and me out into the fresh air?![]()
Agreed, although for some reason people hate the CG-R seatpost on the Diverge regardless lol (will admit I like the sprung seatpost on the Canyon)If you've ever ridden off road on a drop bar, the amount of time spent on the drops is very very minimal. Bike looks odd but I can certainly see the idea behind it. Hopefully these sorts of trends and manipulation of carbon can lead to further improvements for comfort on the bike.
The one on Zwift you mean? YeahSnap : I feel your pain - I was due to ride an event this weekend too and it's been moved. The MMH on Strava worked out okay though![]()
there's a reason mountain bikes have flat bars.
But if they fitted those to gravel bikes they'd have an even harder time claiming they weren't just old-school mountain bikes gently warmed over.
