Can only be around £100/150 to fix it. I had a full bumper sprayed last year for 60 odd quid.
paid £140
Bang on the money![]()
Is there any point getting this sorted out or is it best I just put up with it and leave it alone? If I did consider sorting it, what sort of cost would I be looking at?
A while ago I noticed a small dent on the front of my car that must have been the previous owner's fault. It isn't obvious at all when looking at it normally but now I know it's there it sticks out like a sore thumb. The pictures do make it look a bit worse than it actually is to be fair.
The car is absolutely filthy and it does need a damn good clean but the paintwork is fine and everything is intact even on the dent. Is there any point getting this sorted out or is it best I just put up with it and leave it alone? If I did consider sorting it, what sort of cost would I be looking at?
Looks like they stole your wheels too.![]()
Blooming nora!!
How is it even possible to wreck a wheel that badly?![]()
Blooming nora!!
How do you repair that wheel yourself?? Do you own a smelter?To be fair to her she hasn't had any issues since but went through a little stage of destruction not long after passing her test. I am even considering insuring her on the audi now.![]()
Have you found a replacement yet? Still set on an S-Type R?
How do you repair that wheel yourself?? Do you own a smelter?![]()
seriously though the damage wasn't actually that bad and didn't make it that far through as to damage the bead area so I ground out the damage knocked out the slight buckle on the bead with big hammers. After that I used alloy epoxy to rebuild the profile and away I went
Late reply again, sorry! Strangely enough I ended up going down an entirely different route and bought myself an Abarth 500 a few weeks ago. The idea of a hot (well, moderately warm in this case) hatch appealed, and after a test drive I was smitten.
They're not perfect, but jolly good fun. It's quite 'old school' with the turbo boost. So far 4 people have driven it and all have commented along the lines of 'it's faster than I thought'![]()
Most important thing is that it's got a bit of charm, like the Elise did, so I'm pretty happy with it...For now![]()
