No, AMD do not use solder for their APUs. They have stated that they plan to continue using solder for their CPUs for the time being.What does that mean? only Intel do it, AMD use solder
Agreed.Having to delid K series cpus is one of the biggest jokes in the industry
Let's not forget that "using solder" is not the be-all and end-all. I don't care what compound they use as along as it's decent enough that delidding isn't required to tame temperatures.
Agreed.
No paste is ever going to be as good as soldering so yes actually i would argue that using solder is the be all and end all, is there anything better?
If you're selling 6 core CPU's for £320 its not unreasonable to solder the Heat Spreader, the temperatures on them is not good and the constant limp pragmatism or outright defensiveness by so called Hardware Enthusiasts of Intel's practices in this is what has emboldened Intel to use the same cheap crappy way to bond the Heat Spreader on all their retail CPU's now, including the HEDT chips from the 7800X to the £2000? 7980E or whatever that silly thing is called.
Keep it up guys eventually it might sink in, when Intel are so far in you you're chewing on it.
Note that when people de-lid, they don't solder their heatspreaders on. So yes, there are methods out there that are close to as effective as solder.No paste is ever going to be as good as soldering so yes actually i would argue that using solder is the be all and end all, is there anything better?
It still surprises me that Intel were brazen enough to stop using solder on their HEDT CPUs.If you're selling 6 core CPU's for £320 its not unreasonable to solder the Heat Spreader, the temperatures on them is not good and the constant limp pragmatism or outright defensiveness by so called Hardware Enthusiasts of Intel's practices in this is what has emboldened Intel to use the same cheap crappy way to bond the Heat Spreader on all their retail CPU's now, including the HEDT chips from the 7800X to the £2000? 7980E or whatever that silly thing is called.
The problem with it is, and this is at least somewhat in defense of Intel from my side of this the TIM Intel use is long life, with that it may not be the most efficient heat conductor but its also not going to turn into a hard powder in 2 or 3 years, unlike most of the off the shelf TIM people deliding replace it with.
The penny pinching stingy ####### should just use solder.
i have published a very good paper to have you renamed to No1IntelFanGirl. Would you like to read it?They have published a very good paper explaining why they don't use solder. I'm sure cost is another reason but it's not the only reason.
that was a while ago and that was also me. must be a funny guySure. I like a good laugh.
Last time I had a good laugh was when you were arguing about using crypto in the MM![]()
Every even semi-competent reviewer said that.My memory of ryzen launch was that 4GHz meant you got lucky, there was plenty of talk about how very little ryzen would overclock before it hit the ceiling.
Finally proper no ******** and no speculation testing of retail 8700K.
Tomorrow part 2 that will answer the question.
No testing has been done just speculation.I don't know why that would need to be gone over again, with 10 samples, when the fact has already been established using 1000's of samples.
Did you watch the video? Silicone lottery literally TEST everyone of the CPU's after delidding. Ergo 1000's of TESTED samples.No testing has been done just speculation.
