Caporegime
- 18 Oct 2002
fully loaded is likely to be around 35KG
I wouldn't risk it man, Ikea stuff isn't known for being super sturdy!!! That's a *lot* of weight
That was my gut feeling, think I'll get a solid wood top and some sturdy steel legs, if anyone has some suggestions, I'm all earsI wouldn't risk it man, Ikea stuff isn't known for being super sturdy!!! That's a *lot* of weight![]()
That was my gut feeling, think I'll get a solid wood top and some sturdy steel legs, if anyone has some suggestions, I'm all ears![]()
Can you imagine the feeling as your 3k PC crashes to the ground, that sound would haunt you!Best way imo, as it'll always be in the back of your mind.
Can you imagine the feeling as your 3k PC crashes to the ground, that sound would haunt you!![]()
I bet your heart was pounding all the way home!Worse, it happens whilst you're out!!!!
I remember going to work early one morning and leaving the window open by my PC, storm came in and was absolutely caning it. I came home to find said window flung wide open and a **** load of rain had placed itself on my lovely Dell 30" monitor!! I'm just really glad Dell warranty is so good (after I'd dried it out)
For those of you using the IKEA Alex drawers along with the Karlby Worktop, do you think the setup will support a heavy PC case over the right hand side drawer? My case fully loaded is likely to be around 35KG? It's the Phanteks Enthoo Primo fully water cooled.
That's just the base unit, I'll also have a screen, speakers etc... + an A3 printer on the left side.
Thanks![]()
New desk, need to sort some cable management out.
Nice!
Is that an Ikea Karlby (Oak) with Ikea Alex (Black-Brown)?
The worktop was from worktop express but yes it is oak, correct on Ikea Alex (Black-Brown)
The Worktop Express website says their oak worktops are delivered untreated. Have you treated it with anything, or are you just using as delivered?
They sell a 2m long oak worktop for £95 + £25 delivery charge. This seems very reasonable compared to Ikea Karlby £80 for 1.86m long + £35 delivery charge.
directly over the alex drawers? it'll be fine. ive stood on those before to reach the top of a cupboard.For those of you using the IKEA Alex drawers along with the Karlby Worktop, do you think the setup will support a heavy PC case over the right hand side drawer? My case fully loaded is likely to be around 35KG? It's the Phanteks Enthoo Primo fully water cooled.
Thanks![]()
edit - oops old post.
