- 1 Dec 2015
Ok, how does this look? any stupidity on my part?
Couple of challenges:
GPU is out of stock
Motherboard is pre-order
My basket at Overclockers UK:
- 1 x Gigabyte B360M Aorus Gaming 3 Intel B360 (Socket 1151) DDR4 Micro-ATX Motherboard= £76.99
- 1 x Intel Core i5-8600K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM= £209.99
- 1 x Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD416G24= £139.99
- 1 x Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU)= £139.99
- 1 x Seagate 1TB BarraCuda 7200rpm Internal Hard Drive (ST1000DM010 Previously ST1000DM003)= £36.95
- 1 x Gigabyte GeForce GTX 1070 ITX Edition 8192MB GDDR5 PCI-Express Graphics Card (GV-N1070IXOC-8GD)= £428.99
- 1 x Microsoft Windows 10 32/64-Bit - USB Pen Drive - Retail (KW9-00478)= £104.99
- 1 x Bitfenix Formula Series 550W 80 Plus Gold Power Supply= £66.95
- 1 x Kolink Stronghold Midi Tower Gaming Case - Black Tempered Glass Side Window= £35.99
- 1 x Alpenfohn Matterhorn Pure Edition CPU Cooler - 120mm= £33.95
- 1 x AOC Q3279VWF 32" 2560x1440 VA 75Hz FREESYNC WideScreen LED Monitor= £199.99
B360 and H370 Chipset is only good with NON K intel chips! just as a heads up !
you'll be looking at Z Chipset to take advantage of K chips ability to overclock- though that cooler will limit its ability or temp
Ultra board comes with free CD Key for FAR CRY 5! if not cheaper option
https://www.overclockers.co.uk/giga...cket-1151-ddr4-atx-motherboard-mb-560-gi.html
was also cheaper £20 GTX 1070 but only had 2 year warranty from Palit
cheaper CLC(-close loop circuit) not AIO (- all in one) like one quoted
https://www.overclockers.co.uk/cooler-master-masterliquid-lite-240-aio-cpu-cooler-hs-07l-cm.html
- 1 x Gigabyte Z370 AORUS Ultra Gaming Intel Z370 (Socket 1151) DDR4 ATX Motherboard= £158.99
- 1 x Gigabyte GeForce GTX 1070 Windforce 2x OC 8192MB GDDR5 PCI-Express Graphics Card= £469.99
- 1 x Alphacool Eisbaer LT240 CPU AIO Water Cooling Unit - 240mm (11445)= £78.95
