- 5 Sep 2017
guess I got over excited with it all and put 1080 Ti - good spot. yes meant the 1070 Ti
Thanks for the advice again... down to 2 options then.
is that a 360mm AIO cooler you refer to ? The only options appear to be 120mm and 140mm which is highlighted as being too large for the case. So do I need a different case?
Re Ryzen 7 the only thing that holds me back is the 3.0GHz with max turbo to 3.7GHz does that stack up to the i7-8700k which is 3.6GHz base and max boost to 4.7GHz or is this irrelevant when overclocking ?
build one you'll need a 360 AIO if you intend to get OCUK to OC as high as it can get
