thanks mateFrom Three on contract. No app required.
Strange, I can't find it.Yes. Love it. Doing the TV, virgin STB and DVD player![]()
It's called smart controller.Strange, I can't find it.
It's about the same as my p9.Is it me or is wifi range on this poor relative to other phones? I thought I fixed it turning wifi+ off but still doesn't quite reach as far as my tablet/old phone..
Frustratingly it just seems to stop at my bed at other corner of my house... (so it's a minor difference from my tablet but enough to be annoying..)It's about the same as my p9.
The case that came with it doesn't protect the camera. The camera protrudes more than the case thickness, so when you put it down flat is sits on the camera. Might have to get another case.
Oddly my huawei m3 tablet manages fine (or at least reaches the other side of the house in my bungalow home..which is a good few brick walls+distance worth).Having had a multitude of Huawei phones including the Mate 10 I can confirm that the WiFi range is quite poor compared to other phones.
So far my thoughts
Phone is good, camera is amazing.
However I cant help feeling disappointed coming from the Samsung S7 Edge, a phone two generations ago.
The screen isn't as high ppi, it doesnt have wireless charging and it appears to not work with my car stereo (well not so far)
So really for a phone which on paper costs way more than my Samsung S7 Edge, the only thing which seems to have improved is the camera. Everything else seems to be a step back.
Would be find for a £500 phone but not a £800 flagship phone IMO.
I was worried about this also. Mine should be here soon so I'll try later and report backI'm now concerned to read that majority of Huawei devices are not fully compatible with Android Auto, I might have to cancel my order. Does anyone use it here?
Can confirm Google maps is fine. Not tried netflix yet.Are the screen comments based on what you can see, or arbitrary numbers? Just curious if it's notably worse, marginally worse, or just worse on paper?
TBH I can't see it bothering me. I've gone from a Z3 Compact to a OP3, with an order now in for one of these. I've haven't owned a top-end phone since the iPhone 5S. I'm just curious about how significant the difference actually is.
Issues with your car stereo, plus Android Auto comments elsewhere, plus reported Google Maps issues and the lack of HD Netflix etc. does concern me a bit.
