- 24 Sep 2015
There's something that looks very similar to that near me and when it was being installed I'm sure the signs said it was something to do with gas.
Oh so it maybe nothing to do with BT then. Strange.There's something that looks very similar to that near me and when it was being installed I'm sure the signs said it was something to do with gas.
Could it be something for a fibre splitter to go into? something like
[/IMG]![]()
is this G-Fast kit?
Has your Line Noise (SNR) been reducing itself from 6db+ down slowly towards 3db? That's likely the cause for improvements these days.
Yeah sounds like xdB is working, do you know if you are on a Huawei cab?
It could be G.INP, or maybe just that you're lucky and a crosstalker has moved or maybe a piece of equipment that was causing REIN has been moved/replaced/died etc.Yes, but that was six+ months ago that the 3dB SnR target happened. It's been creeping up since then - the SnR target reduction got me above a 65Mbps sync and now I'm above 70. Just seems counter to what I've seen elsewhere when cabinet take-up starts to result in crosstalk. Unfortunately there's not much logging on the BT Hubs so I can't tell what combination of INP and vectoring is in use. The cabinet isn't G.fast enabled but the Hub is.
G.Fast are 'pods' that attach to the sides of the PCP's not underground, as far as I know.All the BT/OpenReach manholes near my house are being replaced. I've only noticed because first they had a big X spray-painted on them, and then I'd come back from work and they'd all be new, freshly concreted around. There didn't appear to be anything wrong with the previous ones, so could this be a sign that G.Fast is coming to me? They did the one right in front of my house yesterday (the workers were gone by the time I got home), and the one in front of the cabinet was done last week.
Has anyone else had this and knows what's going on?
Wow that's nice!Speaking of which, I've just moved (not far, still in the same town which is a trial area) and my new cab is accepting G.Fast orders.![]()
Look at changing to BT infinity. What is everyone's experiences of BT infinity though? Quite interested about evenings having experienced BT ADSL Max broadband going down the pan in the evenings many a time too as well as barely syncing at 2/3Mbit and dropping regularly (whole area problem...).
Cheers
Michelle
BT routers are locked, there bt infinity VDSLor ADSL line for broadband is fine but you need to use a third party router not theres after its all set up using there router to start with. I use like most people a TP-LINK N300 which is VDSL/ADSL compatable and works great with no problems like slow downs or intermit conections ect. if I use BT router being a HUB 6 smart my line is restricted as far as usage causeing lag spikes and dc ect playing online games . I also got a better speed and ping from using the tp-linkLook at changing to BT infinity. What is everyone's experiences of BT infinity though? Quite interested about evenings having experienced BT ADSL Max broadband going down the pan in the evenings many a time too as well as barely syncing at 2/3Mbit and dropping regularly (whole area problem...).
Cheers
Michelle
