Ok about NEW Crosshair VII motherboard
Raja:
No major change for overall 24/7 OC. Just some enhancements/changes that favor certain setups/usage:
1) VRM phase array changed from 8+4 to 10+2. Better thermal balance across power plane.
Thermal imaging tests were conducted with a Ryzen 7 2700X at 4.0 GHz with CPU Core Voltage at 1.43 V.
No other settings than CPU Core Ratio and CPU Core Voltage were changed in BIOS.
The system was then stressed with Prime95 29.1 Small FFTs 12k for at least 30 minutes.
CPU output power was 175W on both systems. Note that both boards are tested without heatsinks (see attatchments):
2) DRAM layout changed from T-Topology to daisy chain. Some advantages for 1DPC, but disadvantages for 2DPC. Obviously, there will be changes to decoupling as a result.
There are more, too, but Elmor and the reviewers can detail all of that stuff when it's time to do so.
Elmor:
There are small differences due to layout changes. C7H is better for 1 DIMM per channel (1DPC, 2x8GB/2x16GB) but only by 1-2 ratios (66-133 MHz), while C6H will reach higher frequency with 2DPC (4x8GB, 4x16GB).
Amount of capacitors for comparison of boards:
Just waiting for them to confirm that for Crosshair VII motherboard You want 2x16gb not 4x8 for beter numbers/performance.
That sucks, I already have 4x8GB ready to use. :/
