Ended up spending £857£750-800 limit
Ended up spending £857![]()
That all depends on how terribly I build it!!You'll get the bug and keep spending even after you've built it
You'll get the bug and keep spending even after you've built it![]()
you mean posting up pictures and then realising the cables are a mess and tearing the whole thing down and adding braided cables![]()
I've set aside all over Saturday to get it done. Hopefully that should give my cack-handedness enough time!Youll be fine just take your time, i know hiw exciting it is to build your new PC but perfection takes time
Stop youll get him in trouble
You should find the process a lot less daunting - we practically rebuilt your present system which is usually harder than a new build. Certainly, more opportunities for ambiguity in diagnostics.Keep your eyes peeled for a build attempt this weekend..
Obviously, I would prefer a sacking and before he splurges all our money on a mismatched team...I must say, I'd appreciate Mark Hughes being relegated!
You gotta love Ryzen.@Plecthink i just kept it to the £750-800 limit
I think you're using it wrong@Plecand liquid metal is a nightmare, specially when it hits carpet/rugs![]()
and times each by 10 and lots of ATX terminals .......
My basket at Overclockers UK:
- 1 x MDPC-X 15-AWG White Wire - 1m= £0.95
- 1 x MDPC-X Sleeve Small - Orange, 1 Metre= £1.19
- 1 x MDPC-X Sleeve Small - Black, 1 Metre= £1.19
- 1 x MDPC-X Sleeve Small - Platinum Grey, 1 Metre= £1.19
- 1 x Lamptron Deluxe Modding Tool Kit - Silver= £21.95
- 1 x E22 8-Slot Stealth Cable Comb - Black= £0.78
- 1 x MDPC-X 23-AWG Black Wire - 1m= £0.79
- 1 x CableMod ModFlex Connector Pack - 8 pin EPS - Black= £1.39
- 1 x MDPC-X Crimp Terminal ATX Female= £1.49
Too late, I presume you've seen the case I'm getting.. prepare to be blinded@Nathan Long - buy a windowless case - saves money and OCD tendencies
