Looking to get a new wireless charger, what is the best one for <£20?
I've used this one since August last year on my S8+ with no issues https://www.amazon.co.uk/gp/product/B01N0XZDMD/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
mine was doing this too. Cable wouldn't stay in properly either.Anyone else finding the USB port becoming a bit hit and miss for charging? I often have to plug the cable in 3 or 4 times before it will fast charge rather than give me the warning about slow charging. Some cables just don't charge at all any more. Same behaviour across over 10 different cables of varying ages now, so fairly sure it's the port on the phone.
Would use wireless charging more but have a spigen case with the metal plate for magnetic car mount and wireless charging doesn't work through it.
Well my S8+ has got a nasty impact crack on the top left corner, workmate found it laying face down in the workshop, I expected the worst. Didn't even feel it fall out of my pocket! (Was in a Spigen case too)
It's not insured so I'll need a recommendation for a repair. I've emailed a company called PhoneMend who list repairers, just looking to see if there are any others people can recommend?
Other half has suggested I go into Vodafone as it's on contract with them, but I reckon I'll be in for a dry reaming if I do £££![]()
Anyone else getting poor battery life after the latest update (CRD7), i seem to be only getting 10hrs life out of each charge.
https://play.google.com/store/apps/details?id=com.brit.swiftinstaller
New Swift installer system out, you can do everything from the app now without having to tinker with a PC and ADB. Makes theming simpler.
