- 22 Oct 2002
- Hull, UK
Would anybody here be interested if I stuck a US24-500W in the members market?
Serious bit of kit, and i thought my US8-150W was a good performer.
I believe there is a new Cloud Key Controller in the works, might be worth waiting for that.
Just ordered a ac mesh unit to cover the back garden. Tomorrow's task is to run a cable to it
Shame these can't be locked into place to stop theft. I'm going to have to strategically mount it so it can't be seen from the side street over the fence
Why did you buy a mesh device if you are running (presumably a poe) cable to it?
I thought the whole point of mesh was the way it uses dedicated wireless channels for communication between the different devices.
Its an access point if you run an ethernet cable to it...? and one where you have paid for thw mesh capabilities you are not going to use?
It's the same as the other unifi access points with the ability to mesh, You don't need to use mesh, it's the only one in the unifi range that is fully outdoor rated.
NB, the airmax and other models dont use unifi controller either.
I take its better (weather proofing wise) the the uap ac pro's then? Which I think can work outside just as long as their somewhat shielded from precipitation under a wide eave or similiar?
Is that really the v2 cloud key and not some other product? I thought the v2 would be a minor update not something completely different.
EDIT: Ahh there is a v2 and a v2+
Minor change of plan. I'm going to get a Raspberry Pi 3 and use this for the controller software rather than spend the £70 on the cloud key. Will I lose any functionality/features going down this route?Looking to upgrade my home network and have narrowed my shopping list down to the following (probably a typical list for a home setup);
Is there anything I should watch out for? Any gotchas? I'm planning to ceiling mount the APs (cable running issues not withstanding) and use POE. I have 200/20 FTTP via BT and have an OpenReach ONT. I'd like to create separate wireless networks for various groups of devices (Sonos, Smart Home tech, kids devices, etc) and I use IPv6.
- 2 x UAP-AC-Lite Access Points
- 1 x US-8-60W Managed Switch
- 1 x USG
- 1 x Cloud Key
They changed the PoE type on the AC-Lite without making a new part number, did the same with some of the UniFi switches, and there's two types of cameras out there - one passive PoE with an 802.3af adapter in the box, and one with 802.3af integrated into the camera, on the same product codes.
Well it put people in a position of wanting an 802.3af part but there being no clear way to know if you were getting one. I just can't figure out why they can't issue a different part code for a revised product with different functionality, it would save all the confusion.
Sonos
