Any of you guys owned a 335I coupe, opinions on them?
Had one and hated it, got rid of it after 3 months. Poor ride, loads of trim rattles. This was when it was 2 years old, can't imagine what most of them are like now.
Depends what you came from, and also depends how old the review is. Also depends how much you are planning on paying for one...Ok, is it possible you got a poor one? Most reviews professional or just your average forum member highly rates them.
The engines are also quite problematic at this age. Get a 330i if you want an E92 imo
Fair point, although I still think performance will potentially degrade with time.It's not a spring, it's actually a bellow which splits with age - they either work or they don't, rather than a shock absorber which degrades with age, hence they don't get replaced as a pair.
Good thread on them? On my mapped 330D F30 (less torque but more power) there was quite an eye opening difference when I swapped to new Continental CS6, even though the old ones had around 3mm of thread left.mich pro pilots
Yes. I had three of them and the first two I escaped with only normal maintenance costs. The third however, with the "more reliable" N55 engine, really did bite me in the arse...
Waterpump, Valvetronic system, DME (ECU). All failed within days of oneanother. Cost £3700 in total to fix all that, a wonderful experience. Would have been £5500 if BMW UK hadn't contributed goodwill.
Not particularly old or high mileage car either, 2010 with 53000 miles.
Very nearly PX'd the car a month or two prior to all of this. Gutted!
started looking at focus rs pretty sure I'm going to go in that direction but heard it has poor driving position so will have to wait and try one firstAlso remember that Fox has different expectations to most. He's literally spent all his life in a 5 series (not literally) so his expectations will be different. Whilst I understand his point, if the cars were really bad they wouldn't be very popular. Perspective is key here.
Did you seek a non-BMW quote?
Vauxhalls are popularAlso remember that Fox has different expectations to most. He's literally spent all his life in a 5 series (not literally) so his expectations will be different. Whilst I understand his point, if the cars were really bad they wouldn't be very popular. Perspective is key here.
Just a question which 330i engine is the one to avoid after the m54? N52 or n53?
Don’t think they fixed this in the f30 either, mine squeaked like some mega squeaky thing until I took it in and the dealer spent a day fixing all the squeaks, all except one where the idrive screen lets out a squirm when going over bumps. Was told that they applied 2 loads of tape to the fixings on the screen but it still makes a noise.
I'm incredibly satisfied now.The N53 is the complicated one. It is a stratified direct injection which delivers great fuel economy but brings with it added complexity.
Do you happen to know when they started to use the n53? Was it after 2007 or in the LCI?
