Thanks guys.
Any tips for settings? balanced or Turbo? and HBCC Memory Segment off or on?
Cheers
Its a sapphire vega 64 nitro+.
I'll give them settings a try.
Thanks
State 7 was set at 1250mv so ive knocked it down to 1150 and 1050 for 6. Ive not touched the clocks as they are set to 1537 and 1632.
I've upped hbm to 1000 and lowered the mv to 1050 from 1100.
Just had a quick go of farcry 5 and its way smoother than before.
Thanks for the tips.
Is HBCC enabled?lol what's this 18GB of vram util on my Radeon overlay?
No it's not, I've never used HBCC. I guess it must be a bug in the current and maybe previous driver. System RAM was at 6.2GB btw.Is HBCC enabled?
Matt, I don't suppose you know why the original 3 x 8 pin power arrangement was changed on these Sapphire Vegas? There wasn't a spec change to the chip or anything like that?
Maybe Sapphire just ditched the extreme overclocking option to cut costs![]()
The Vega 64 Nitro with the three plugs was called the limited edition version, Like with most of AMD's hardware nowaday's overclocking is minimal as they're close to maxed as they come, I had the 3 plug Nitro & it never clocked any better than how any other can clock from what I've seen & read. I had an air cooled reference Vega 64 before the Nitro LE & it was the temps, throttling & noise that stood them apart not the clocks.
Thanks for the info, I was just curious as it was unexpected to only find two connectors when I opened the box, thought I maybe had a dumbed down version or something![]()
If you are on air, try not to exceed 1100mv on the core, will generate to much heat. Just go easy but 1600mhz around 1000mv/1050mv should be easily achievable but not knowing your card it's not something that is guaranteed. Just take your time with it.
970mv and 915mv is what I have for near default speeds and obviously thats usually a ton less power then out of the box, hence all the criticisms are a bit silly when I think most can use these settings. For the overclocking stuff you would need more I guess depending on ambient and cooling
Hopefully I can get a year out of it before needing an upgrade. Not as much disposable income these days xD
Off topic:
Windows 7 vs Windows 10 Test in 8 New Games
you will se a vega refresh in the next 6 monthsgonna be 18 months minimum before AMD release anything better so you're safe, possibly for another 2 years.
