Are you sure you're not looking at the X34A?
EDIT: Nevermind...I see what you mean![]()
You found it then! I think it was a miss-price.
Rather typically, I bought mine last week...
Misprice for sure then, damn shame. Thought it was a little crazy!!
A different cable seems to have done the trick - thanks for the tip
The backlight bleed is kind of annoying, but I think I can live with it. Better at the bottom corners than the top. Hardly ideal for a £900+ screen tho...
The one I was using was the one supplied. I switched it to another dp cable I had (can't remember exactly where it came from), and the flickering stopped. Today I switched back to the original cable, and there was no flickering. So maybe it was just that the cable wasn't seated perfectly? Either way it's back up and running with the original cable. I hope you get your flicking issue sorted too!What cable were you using when you had the problem? The original one that came with the monitor? and what did cable did you change to?
I've just unboxed mine and the screen seems to blink very randomly too. Im connected using the supplied DisplayPort cable.
Any ideas?![]()
As the acer has gone from shops is there a new one in the pipeline ?
I doubt the X35 (ultrawide, 200Hz, HDR) will be out anytime soon seeing that the X27 is out at the end of the month and they'll want to promote that as the top product!
