- 18 May 2010
- London
we all know yours motherboard is junk including Youif ya want we can swap kits ill be happy with an upgrade
Others with the same mobo have the ram higher than DOCP.
ye but Yours motherboard is **** init ?? I was sure You ordered different one by now....Others with the same mobo have the ram higher than DOCP.
That's not a complete certainty. I have seen a couple of reports of people getting B-die in CL16 3200MHz kits. No proof to hand as it was ages ago, and you certainly wouldn't buy a CL16 kit expecting B-die, but it's not totally impossible. There are also definetly CL15 3200MHz B-die kits that you can reliably assume will be B-die. For instance:If it was B-die it would be rated at 14-14-14 3200 @1.35v. In the link you posted it was rated at 16-18-18-36, It's not B-die simple as.
It is b-die i checked with Thaiphoon Burner, Die density / Count samsung b-die (20nm) 1 die
Yup there is S die and E die also besides B die not sure what Die will 10nm one be CANT WAIT to get my hands on new samsung 10nm memory nom nomWeird that, since it's the Samsung S-Die that is rated to those timings, and what a lot of the Team Group kits have on them. I am pretty sure that last kit I had, albeit the T-Force variant was S-die, but that was for an Intel build not Ryzen so couldn't comment on the compatibility.
Mine is the vulcan t-force, i dont get home till midnight tonight but i will post the thaiphoon screen here. Either way it doesn't work at 3200mhz so doesn't matter .Weird that, since it's the Samsung S-Die that is rated to those timings, and what a lot of the Team Group kits have on them. I am pretty sure that last kit I had, albeit the T-Force variant was S-die, but that was for an Intel build not Ryzen so couldn't comment on the compatibility.
Ask how many hours did @opethdisciple spent lolThose kind of speeds above are pretty rare though and often take hours and hours of tweaking to achieve.
And this is how GOOD b die memory is and its on 1700x with 4100mhz !!!!
@kitfit1 check those out its Gskill 4266cl19 at only 1.42 volts where I need to pump 1.46 to have my 3533 without errors
thats difference Good vs Descent B-die
https://image.~ibb.co~/dkBQaJ/3600_All_Test_T1_GD.jpg
Jesus that benchtec site is awful, don't click that.![]()
Got my Corsair Dominator Platinum 3200Mhz Hynix running with my 2700X as high as i could get it running with my 6700K which is 3000Mhz 15-17-17-35-1T. Cost me £100 in 2016, its £219 right now on OcUK.
https://www.overclockers.co.uk/cors...l-channel-kit-cmd16gx4m2b3200c-my-468-cs.html
Is the RAM cheap or was I cheap in 2016?
LoL
The problem is Ryzen, its still new.. get over it.
By now on hes place i would take that motherboard and threw it out of window. or sell it on ebay wfor 30 quid just to not look at it.
Afaik it took him just a week to get those timings right and remember its on 1700x not 2700x !!!
naaa those prices wont evet be backIndeed, you could buy 16GB DDR4 3200 MHz Corsair LPX for £47 in June 2016, it's going to be a while before they drop that low again.
Well if You would have same problem with C6H that would be user error no other option,The board is good though with decent VRM and features. It only cost me £110 from b-grade.
The problem is that the ram compatibility has got worse over time. since 3200 worked fine on an earlier bios with my 1700.
I'm just going to run 3066 for now and hope they fix it. Tempted by the Crosshair vi in the MM but I might just have the same problem.
