- 30 Dec 2004
- Bromley, Kent
Get a HG612 3B. Plenty of them on eBay but don't pay extra for an unlocked one as you can do that yourself.
Cheers, will take a butchers.
- GP
I have the same switch after a recent install. Bit bulky but hey, whatever works. Same modem I use too. Did they give you that as part of the install?
Your install could be even neater if you’d used the internal IDC terminals instead of plugging into the front. You'd probably have to be able to crimp a plug on to do it.
It’s a shame that PoE extractor is black. Whose injector/extractor kit is it?
Well, this is the latest news I have. Fingers crossed!I have asked BT Openreach why new build houses houses 20 foot from mine can get FTTP but mine can't. One of their senior engineers has emailed me and is looking into it. I know it'll probably end up going nowhere but I thought I would ask.
Hi Chris,
By way of an introduction, I work for Andrew Whale, our Chief Engineer for Openreach;. Clive has asked Andy and team to look into your email.
I’ve spoken to our regional team and they confirm that there isn’t a plan currently to cover your property with a fibre to the premise solution, however, I have asked one of my colleagues to survey and cost equivalently to do this.
Once I have this I will seek financial approval and let you have the outcome.
If you have any questions please don’t hesitate to get in touch with me directly.
Kind Regards,
Sharon
Edit.£10k <minimum>
Edit.
This isn't me asking OR to provide an FTTP OD quote, I'm asking for native FTTP to be extended from the new houses next to me into my house (and maybe street, depends what they say).
Oddly, the modem has come into sync and I've lost the ability to get to LAN2, it's showing powered up and rightly so it is but no LAN connectivity. Odd but I can live without DSL stats for the time being.
Just that awkward wait now as the phone line has been activated but Plusnet haven't yet completed the order (so no ppp).
Yes. I have an RB3011 which is using the connection to the HG612 as my primary and now my old line is the secondary.This might be an obvious answer. But do you have a router? The H612 is used as a modem, then you connect your router. It's the router that does all the connecting to the isp stuff.
Probably the living room one.Mhmmm I've moved into a flat where there's 3 Telephone points, 2 in bedrooms and one in a living room - all look like extension points - none labelled master/have tester points.
Plug into any of them and hope for the best?
Rebooted my router yesterday to enable a feature and the sync speed dropped from 74 to 71 Mb/s, the first time I've ever seen it drop that much. SnR is 6.4 dB up and down, which I'm pretty sure was not the case for the down path before. Kinda weird.
