Not had any problems with it @Gee.
Cheers fella. Will give it a go.
Am I right in saying any overclock now downclocks at idle on 3502?
Do you think the onboard audio will be enough to power beyerdynamic DT 990 Edition 250 Ohm? I'm considering these or maybe the aka 720, if not might just play safe with ausb headset
Thanks for that, I though it may need a amp/dac I will need to do some more reading![]()
I have the 990 250 Ohms and it sounds decent for onboard but don't expect it to go too loud or to get the clarity of a dedicated setup![]()
What amp/DAC are you using to run them?
I am thinking about getting a a pair of DT 990 Pros as upgrade over my existing QH-90s but an unsure if running them off the motherboard's audio or getting a cheapish DAC, possibly a FiiO E10K, would give me a good lift in sound quality. I don't want to go too far down the rabbit hole of spending loads on audio.
EZ Update only gives me version 1501 bios for this mobo and nothing newer. Am I safe to flash the 6101 version?
6201 is out. Anyone tried it? Reading reports of fans stopping at random and only a reboot fixes it. May stay on 6101 for the time being.
