@orbitalwalsh @freddie64 @Jamin280672
Chaps, ive been asked to put together a presentation for work over the weekend and need to use the pc. Im going to pick up a PSU and hope it works.
Im going tonget one on amazon prime, is a 600w ok for my system?
Nope I was stuck on the CPU and RAM LED, both were on together. to clear the CMOS its just 2 tiny little pins that you have to short, you don't have to put any pressure on anything, just lightly touch them with something metal, or grab some jumper caps off ebay or an old motherboard or something to short them, my 2 pins are just above the 1st PCI-e x16 slot, you'll have to check your manual for where yours are.
Stupid question but im assiming you need to be powered on to do this?
No, power off, remove the kettle lead, press the power button a few times to drain the capacitors, then clear the cmos with the pins for about 10 seconds, plug back in the lead and switch on.
Ok mate, I will have the PSU back early next week, will give it ago then and see what happens, I will let you know how I get on.
Do you just link both pins with a piece of metal for 10 seconds? Do I take the battery out?
No need to take the battery out, and yes just link the 2 pins together, some things work and some things don't, for instance a kitchen knife didn't work for me, but my car key did, so try a couple of thing, if your PC is down now without a PSU in it, then there is no harm in clearing the cmos with the jumper pins now.
Sorry chaps been very busy.
I ended up getting the PSU back and then sent back the CPU, RAM and Motherboard. After testing they found the Motherboard was faulty amd not posting. So it seems like it was the motherboard all along. Im now waiting for a replacment to be sent out and hopefully that is the saga over......... hopefully![]()
Sorry to hear bud, of it takes over a week from OCUK sending it off, drop a message to rep on here and will be able to dig it out![]()
Hey bud, as I recall you had Pure 600 case was it ?
Those fans are connected yes to the cases own controller , which is powered via a sata power cable
Could be sata cable gone or port .
Try another cable and move to a different port .
Also pull the CMOS battery/board batt for 5 mins and out back
The case fans have 3 pin connectors , they are plugged into the case controller , but to power the fans , the controller draws its power from a sata power connector , otherwise they can't be powered unless you connect them direct into the board.
At the back of the case, follow all the case leads coming from the front/top connection ports. Should find the lead for the fan controller that needs to plug into a lead from the PSU
