I can see where you can turn this feature off, but is there a way to remove it from the notification bar?
You can via GoodLock from the Samsung store. You can also disable a range of other icons from the status bar too.
I've just installed good lock from the Samsung store and can't see anywhere to turn this off, could I trouble you to point me in the right direction please?
Picked an s9 up today what's the best cases to put on these?
On Matt100's recommendation I recently bought a Gear4 Battersea with 'D30'. Supposed to offer good protection should the phone be dropped. Affords extra grip to the Galaxy and not too bulky. Isn't a cheapie at £25 from Carphone Warehouse. Nothing special but gets the job done and is tidy enough.
I can't decide whether to get one of these or not.
The main attraction is the hybrid SIM slot so I can ditch my work phone but does it work well and does running two Sims kill the battery?
The guy at CPW demonstrated that case to me by bouncing his personal S9 off the floor. I went looking for it cheaper elsewhere but without success.
Yep, makes no sense. Google are losing the plot regarding YT. They're copying IOS too much now and this is perhaps one of their dumbest decisions. I'm already moving to YouTube Vanced because I'm sick of a million daily updates to the YT app alone.Anyone noticed you can't skip through a video using the YouTube app anymore?
Well you sort of can, you now have to hold the little circle and move it left and right. You used to be able to just tap the video along.
