- 24 Aug 2005
- Uranus
Yes works quite well although I would like some more resistance.
Use Joystick as handbrake?
Just ordered my 3rd sensor, think a few of the games I plan on playing are room scale. Have they added in support for a 4th sensor?
I use a "UGREEN 4-Port USB 3.0 Hub with 1m Cable" from the rain forest works great for 1 sensor and HS for me having 2 sensors in seemed to cause issues.Any recommendation's for a powered usb hub?,all of my usb ports are used,and had to plug my keyboard into a front port as the usb on the Y section of cable is very short,so need recommendation on a single usb extender cable too,thank's all.
Thank you,will take a look at those now.I use a "UGREEN 4-Port USB 3.0 Hub with 1m Cable" from the rain forest works great for 1 sensor and HS for me having 2 sensors in seemed to cause issues.
Has a optional (not included) power input that I dont use.
Finally got my rift today and ran into a small problem. My gpu has 3 display ports and only 1 hdmi.
So I need a DP to hdmi adaptor. My TV is 4k so will I have any problems with this?
Also can I get sound to come out of the TV as well as the rift? So people watching can hear what I'm hearing
for my Rift. £8.99.then
- Open Oculus Home
- click the Gear icon in the top right
- Select Settings
- Choose the picture of the headset labelled Rift
- For "Audio Output in VR," select Both (audio mirroring)
- Back in Windows, left click the volume icon in your system tray (bottom right corner of your screen)
- Change the output device from the Rift headphones to your speakers.
-I use, 'CSL - 4K Ultra HD Displayport to HDMI adapter with audio transmission'for my Rift. £8.99.
-Nah
-Nah
Sorry just to check - you run the rift on that displayport to hdmi adaptor or you run your 4k screen on that and the rift to the native hdmi?
I'm currently using a Ugreen displayport to hdmi adaptor for my 4k TV but it's rubbish - screen comes on with green fuzz for about a minute until it then vanishes and when the display sleeps sometimes the only way to get image back is to unplug and replug the connector. I tried it on my rift rather than the 4k tv and the experience was awful with picture cutting in and out etc.
Hyperseven on a roll.![]()
-Nah
Nope, one rig for both. I was considering a second rig for the living room to play vr games but sanity and my wallet told me no.Do you guys run a dedicated gaming rig for your VR stuff and a different rig for pancake?
