Valve stem seals will manifest when the car is warm. Start it and let it idle for a minute, then rev to 3000rpm. If it smokes the seals are shot.
The valley pipe is on all of the N62 engines from the *45s to the *50s.
Well if that is the case certainly wasn’t any smoke. On the subject of the valley pipe, isn’t there a method when the engine doesn’t require to be fully stripped down? Isn’t there a method when you remove the water pump then you slide another pipe in? Sounds like a bit of a bodge but I read a few articles on it, when I thought it was only the 645.
- but I don't blame you one jot. As you said, things can go wrong quickly on the ring and the last thing you'd want is an expensive car smashed to bits with no insurance.
