Avoid the white leather if you wear jeans. It stains really easily.
- Dakota leather - Ivory white/ Black world
Any feedback on the spec and value is appreciated.
Thanks!@Havana_UK Lovely car and great pics! See loads of M4 about but hardly any M3.
You can buy android head units for the E39When I purchased my E39 the stereo wasn't playing through a couple of the speakers so I swapped it out for another genuine E39 stereo and, same problem, but with different speakers this time.
Wanted to keep OEM look but there's no way I was going to throw too much money at getting it set up, so I opted for a Sony head unit. £90 including the wiring harness and fascia.
Now it plays through all of the speakers!
Pretty decent sound, too.
Is emergency service just breakdown cover? Not worth ~£100
I'm swaying towards the comp with £100 excess and no emergency service or equivalent at £250 excess to be honest. I can easily renew my old AA cover for £20-30 for a year, saving a fair chunk. No requirement for cover in Europe nor a hire car as work is flexible.
You actually get standard recovery included in the warranty - they'll come out to the car and recover to the nearest dealer if they can't fix it.
BMW said:Yes. A facility for UK roadside recovery only - Warranty Assist - is included with BMW Insured Warranty.
Please note that this service is limited to recovery to the nearest retailer within the UK only and is not a replacement for the full assistance services and benefits provided by BMW Insured Emergency Service at home, elsewhere or on the road in the UK, Republic of Ireland and Continental Europe. BMW Insured Emergency Service cover is available as an option with all BMW Insured Warranty policies.
I have one
If you are good at spannering then they are OK to run but there will come a time when you have to get the valve-stem seals done. If you can find a garage with the tool then expect to pay £1k. If your local garages want to remove the heads to do the job then factor £2.5k.
Put it this way. I've recently replaced the CCV diaphragms, MAF, and VANOS solenoids. Because I did the work myself it cost me £200 ish in parts. Add a 0 to that to have a garage do it for you.
They are based on the E60 5-Series and so many parts are common to both models and most independents can work on them with no real issues.
Stuff that can fail:
CCV diaphragms and any of the associated tubing (manifests itself as poor running and smoke)
Valve stem seals (white smoke at startup or when revving after being idle for a minute or 2)
Factor in a transmission fluid change if it's not been done and the car is around the 80k mark
Water pumps fail
VANOS solenoid seals fail (poor low-speed running and rough idle)
Rocker-cover gaskets fail (causes smoke and poor running. Easy job you may think but factor on 5 hours just to get the covers off and another 5 to put them back)
Valley pipe (car leaks water from a weep hole at the front of the engine. BMW will want to strip the entire motor to fix (£7k+) but a stent is available that will sort it for a few hundred.
That's the major stuff but you're going to have lots of little niggles I expect as you're talking about a hugely complex car that is 13 years old.
I'm very happy with mine but if I wan't happy to get my hands dirty I would not be running one as I know that they can throw up some crippling bills.
