 - 29 Dec 2009
x
							Fall off and makes sparks on roadIntake manifold?
This thread covers pretty much everything
https://type-r-owners.co.uk/forums/...ing-guide-check-list-for-the-FN2-Civic-Type-R
What part of the country are you in?
buy my old one:
https://www.locateacaruk.co.uk/used...-vtec-type-r-gt-3dr-lichfield-201807148449552
P.s. dont really
Ha why what's wrong with it ?
mechanically absolutely nothing, runs sweet as a nut and just had a full blown service done.
it got keyed down one side and had a very good touch up job, but you will eventually notice it and it will drive you absolutely mental. I do miss it though great car
They are absolute barsrewrd scumbags.
Had it with my mr2![]()
yeah really wound me up, its what made us move area, and the fact my garage got emptied and my car emptied twice.
Made me fall out of love with the car a little bit knowing it was there, you genuinely cant tell until you are up close cleaning it the guy did a great job.
Get on the Civinfo facebook page theres often people selling very well looked after examples on there.
That's awful and Yes I can appreciate that it does
Thanks will do.
Whats your budget?![]()
Taken to the garage today after failing again when starting yesterday. Looks like the motor on the steering rack has gone and it needs taking to the Honda garage to get fixed. Might be an expensive one...You should probably look into that before it fails completely...
I got mine from Amazon IIRC. Either that or try Tegiwa/ebay etc.Wheel arch lining rivets... Can anyone link to one that will actually fit? Tried the two types Halfords stock. First one was too short. 2nd not wide enough. Hoping the 3rd will be juuust right.
