Already halfway through Q3! hope to get a date soon
Tried looking at Roadmaps, only had old ones, Q3 was only time mention, know week numbers.. guessing it was set flexible to match AMD
and thats what they are listing, unless you know their engine/ source code by heart ? hopefully if its true what they are recommending - its showing more cores being coded in for which is a good thing finally![]()
I hope games dont require stupidly fast cpu's, not yet as Im hoping this 8086k will last me as long as my 2500k did, or longer
hard to say. 2500K lasted a long-ish time. If you think about it it launched in 2011 and only by end of 2017 did Intel change the i5 lineup to 6c.I hope games dont require stupidly fast cpu's, not yet as Im hoping this 8086k will last me as long as my 2500k did, or longer
I do agree, I think the next battle (upcoming) will be core count. It's pretty easy and cheap (in terms of R&D) for Manufacturers to simply "bolt on" MOR CORES! and we are seeing AMD do his with TR to the extreme.hard to say. 2500K lasted a long-ish time. If you think about it it launched in 2011 and only by end of 2017 did Intel change the i5 lineup to 6c.
I think we're going to see a bit of core battle in the next couple years, given how AMD is playing this. i5's in 2 years might be 8c(or 6c/12t) parts. It's hard to predict anything because we didn't have any competition for a lot of time, but now IT'S ON!
There's really no reason why we should require faster cpu's when there's a load of unused cpu cycles on multiple cores that could be put to use. If devs put more time into optimizing for that and taking advantage of the available cpu power then we'd likely see better performance.
Any idea of release date yet for 9900k and z390 mobos? Heading to the states in September and would like to pick one up.
Wow. That would actually make it much the same prices as here. certainly close enough to make it not worth buying out there. Trump innit.Bad news it would seem... https://www.techpowerup.com/246596/...-as-25-import-tariffs-take-effect-late-august
Is that not just between china and the u.s?
