Can anyone with a Ryzen Processor and Radeon card replicate this poor performance in GTA V?
Usually far north of 60fps and much better than my old 3570k in general but scenes at night with lots of lights in the distance seem to bring the framerate crashing down (~44fps). As far as I know this does not affect Intel and Radeon or Ryzen and Nvidia setups. Frame rate is the same even if I drop resolution as far down as 1280x720.
Map location to replicate
Looking in this direction:
And here:
Card is running hot. 75C is bit much. However GPU utilization is low, 21%!
That's an issue I have seen even on Nvidia cards with Intel CPUs. Hundreds of similar threads.
Reduce your shadows one notch, and remove the side panel of your PC to let the GPU cool down. Seems you do not have enough positive airflow in the case.
