All that untapped potential going to waste.Same here, ive never touched my 64, runs great as is.
One of the reasons i got the liquid, no having to **** about with fan speeds, volts etc...
How exactly do 6 to 8 pin connectors work? I've got a 700w psu with an 8 and a 6 pin. Is it possible to just use one of the 6-8 adaptors? Or alternatively what's the other option for powering the 64?
Which PSU have you got? I assume the 8- and 6-pin connectors are on separate cables?
It's possible that your PSU actually has three 12V pins connected on the 6-pin cable (a standard 6-pin only has two 12V pins), in which case a 6-to-8-pin adaptor would connect up the additional ground and sense pin fine (via the existing ground wires - there will be three) without risking any overloading.
If not, then I wouldn't use such an adaptor and just use the 6-pin as-is. The GPU should still work fine at stock, but I wouldn't expect the best overclocks possible as the 12V will droop a little more under high loads.
It's an OCZ StealthXStream2 700W. How would I go about finding out if it has the 3 12v pins required? Unfortunately, OCZ apparently went under, so I've had trouble finding a copy of the manual, though I did find this:
http://static.highspeedbackbone.net/pdf/OCZ700SXS2.pdf
And that appears to say the 6 pin has 3x 12v pins?
AmenAll that untapped potential going to waste.![]()
Well, Powercolor ordered, Gigabyte RMA organised.
Big pain, means I need to wait for Monday rather than getting to play with it this weekend, but worth it in the long run. Thanks for the heads up, and for OCUK for letting me send it back so easy. Just glad I didn't open it or I'd be kicking myself.
Any word on the vega Nano? All I have found on the internet are pictures
Cheers mate.Be worth tagging him for that Nash,
I don't need all that 'untapped potential', already rippin through my games![]()
I'm BACK!
This is how she compares to here 480 sibling. A virtual cookie for anyone who can guess which is which.
One for the owners list please Kaap, Cheers.
Hehe I was playing with the cooling today. 1900 core clock is achievable, if I bother to buy a 360 MLC now and keep the V64 in it's own loop.
Right now I blame the 8600K for putting too much heat into the loop![]()
I'm BACK!
There's no way any Vega card will do 1900mhz on the core. When I was aggressively benching mine after I first got it, I was bricking it at 1850mhz. It felt like it was going to go pop at any time due to throwning 1250mv at it. It's one thing setting wattman to hit a target clock, actually getting it there is another matter. I wouldn't advise running any Vega card over 1800mhz for 24/7 gaming.
