- 14 Oct 2007
- newcastle
I was thinking of downgrading, if your interested I will list it in the MMWhy do X399 boards have to be so ridiculously expensive?!
You're not getting it.Comes from the same flawed logic as:
Let's not build a new cpu, no applications need the power.
We should build new hardware to drive software changes.
There's no flawed logic
The issue is if Windows and applications are going to get confused by so many threads,then it probably means X599 will start to have the same problems too.
What are you basing this assertion on?The problem is Windows....
Most of the people who buy these sort of CPU's don't use them in Windows, Windows is junk it cannot handle the power they have to give.
From the review
"Final Thoughts
It’s not going to be difficult summing this one up. Without question, AMD is offering an unbelievable chip with the Ryzen Threadripper 2990WX. I’m still surprised that it even exists, more than most, it seems. I just couldn’t see AMD literally doubling the core count after a single year, but here we are.
I’ve talked lots about core counts, but in actuality, it’s not the core counts that really matter at the end of the day. Do you buy your Radeons and GeForces based on their core counts? Probably not. What you want is the overall performance. The same principle should be applied here. On one hand, it’s unfortunate that AMD needs 32 cores to only just beat Intel’s 18-core in select tests, but AMD’s charging about the same($1799) for its 2990WX that Intel is still charging for its 7980XE ($1850).
But it’s not those select tests that are going to matter to most people who are reading this review to learn how the chip can impact their workload. Like any workstation scenario, not everyone’s needs are the same. One chip might excel in one area, but if it’s not the area you deal with, then the point is moot."
For example:
Look at Linux reviews, the 2990WX is faster than the 7980XE in every single test, often hugely faster.
https://www.phoronix.com/scan.php?page=article&item=amd-linux-2990wx&num=4
Too be fair to MS I don't think anyone could have envisioned a world full of reasonably priced 32/64 thread desktop chips offering this level of performance. Well not this side of 2025 at least.
