No it's overkill.
Indeed, 128gb with a 128gb SD card should be more than enough
No it's overkill.
If anyone is interested copied from XDA
Quote:
Originally Posted by alfred_mcskee In case anyone's interested I've just come across a great deal for two Ringke cases if ordered through Amazon UK. Only 99p each! Seems one per customer (though you can order one of each as I did)...
https://www.amazon.co.uk/Ringke-Brus...yJL&ref=plSrch
Use code "UKONYXN9" at checkout &
https://www.amazon.co.uk/Ringke-Ergo...f0L&ref=plSrch
Use code "UKFUSIONX9" at checkout.
Hope it helps!
Sent from my SM-N950F using XDA Labs
Cheers, so if you've not got prime you've got to pay for 2 lots of delivery charges.I did it separately, worrie fine.
Hope it helps!
Well they don't 'replace' Google Assistant and Google/Android Pay, they just run alongside them. When I had Samsung phones I always disabled the Samsung apps because Google's were much better anyway. Google Asst and Pay work just like on any other Android device.I have my eye on this phone at the moment but it'll be first Samsung. I've generally always had Nexus' or LG's in recent times, so stock Android.
I know Bixby replaces Google Assistant, and it seems Samsung Pay replaces Android Pay? What else should I expect from Samsung (good or bad)? I would be tempted to root but unfortunately I have to be able to access banking apps etc for work so that's a no-go.
The android pay and assistant still work fine. I use them all the time. The Samsung alternatives run along side them so you can use which ever apps you want.I have my eye on this phone at the moment but it'll be first Samsung. I've generally always had Nexus' or LG's in recent times, so stock Android.
