I really can't see 1080ti coming in at less than £500. Unless it's some strange end of line deal that Gibbo has been known to pull off very occasionally. I'd expect them to settle at £530-600 while 1080 comes down to around £400. 1080's are nearly there as it is.I’m hoping the 1080ti drops a couple of hundred when the 2080s get released ..
Thats exactly what wrote few pages back.
With 7nm looming this is similar to 8800GTX/GTX480 card. They looked great (compared to 7900, GTX280) the year they came out, but straight away superseded in less than a year with far better and cheaper products. (8800GT, 9800s, GTX580)
Of course people will moan at you, because the point you are trying to make is daft. You still don't have to pay AMD anything to use VRR. And the Licence fee for HDMI has to be paid if you use HDMI whether it is VRR compatible or not.
AMD calculates TDP based on boost clocks my friend(Vega is more complicated tech and the minds of Nvidia crowd cannot comprehend the technical stuff)
My Nitro+ has to be overclocked to it's limits (close to 1747) on air to hit 345W.
True it doesn't scale linearly, but I can tell you 170-176W the Vega 64 runs at 10-15% over the base clock (~1400 cooler depending), and 80W at close to base clock 1260.
Also 276W power limit (Turbo Mode) is 1630 clock (effective 1570-1600 cooler depending) on Nitro+ and Red Devil.
Factory overclocked GTX1080Ti at 2021ish like the Lightning, Xtreme etc need 330-350W maxed out not 250W.Because Nvidia like Intel calculates the "official TDP" on base clocks.
I had the 1080Ti Xtreme and mine like those on the reviews of those top of the range 1080Tis show the same power draw, 330-350W at factory overclock speed.
The downside to AMD's RX Vega architecture is higher-than-GeForce power consumption. The above graph shows system-wide power at the mains, and the Sapphire beast consumes over 100W in excess of a partner GeForce GTX 1080.
This is the figure for the out-of-the-box balanced mode. Activating 'turbo' increases it to 438W and going by our calculations, results in a negligible increase in performance that is not worth talking about.
Flicking it down to the second Bios position, which knocks a couple of per cent off the performance, further reduces consumption to 344W, which is still notably higher than a GeForce GTX 1080.
There's a lot of false information being posted at the moment. It's a sign the new cards are imminentWell terrible sorry if correcting false information isn't to your liking.
HDMI is not a free and open standard.
I thought your 176W must be a typo because you're claiming that your 64 is more efficient than a reference 1080. Sorry I can't take it seriously as I presume you're undervolting so it's not a valid comparison.
1080Ti Power Consumption
https://www.pcper.com/reviews/Graph...-Ti-Review/Detailed-Power-Consumption-Testing
Vega64 Power Comsumption
https://www.pcper.com/reviews/Graph...4-Vega-64-Liquid-Vega-56-Tested/Clocks-Power-
Had a look at a couple of Nitro + reviews (both had similar results)
https://hexus.net/tech/reviews/graphics/113198-sapphire-radeon-rx-vega-64-nitro/?page=8
Finally, why do you feel it's necessary to go OTT? You acted in the same fashion during the Vega launch.
Only issue is state tax is not included, so difficult to get a like for like comparison
Nvidia live timer on Twitch:
So looking at that timer,that is 5PM today for the announcement.
Just going to chime in. As far as I'm aware nobody is undervolting 1080s to get them to run at over 2000mhz (or at least to get max oc), but instead increasing the voltage do get there. This is going to quickly put up the power consumption to well over 300w. The Vega card however, is able to get much better overclocks and much more stable clocks when it's undervolted. Trust me i'v ran about a 1000 tests in the last few days trying to get there on a reference card.
Anyway if both the cards are using similar power and you actually have a vega that can go steady over 1700mhz then it will be the more efficient card because they are quite a lot faster at these speeds.
So yea max oc vs max oc vega is more power efficient. You could argue but since when did anyone on this forum care about factory settings.
