Just... A proper messy weekend but loved itStill alive after Holland m8? I'm almost.....disappointed![]()
How was the nvidia green lol...Just... A proper messy weekend but loved it![]()
LOL. Didn't try it, as this is a family friendly forumHow was the nvidia green lol...
FakeFactory modded HL2 with RTX, i get over 100fps @ 3440x1440 on my 64, max settings
Well looks totally unrealistic. Never seena floor like taht thats not made from some sort of black mirror maybe ??
I’m so pleased I cancled my 2080 pre-order and gave the guy who bought my 1080ti his money back, never been so pleased with what I already have!
Well if ryzen gained 200mhz going from 16 to 12 then i cant see why this should not be the case ?? I expect them 2080s to overclock around 2.2. Depends how hard THP limit will hit tho :/You should take core clocks with a massive grain of salt in Futuremark applications, too
So what You think it will be max on water on those?You cannot compare clock speeds across different architectures.
Boost is noted to be 1635 on the FE in OC mode, so it's possible they will reach 2GHz but I wouldn't count your chickens. At this point, it's anyone's guess.So what You think it will be max on water on those?
just found this online take from it what you will
https://wccftech.com/nvidia-geforce...ghz-and-beats-a-gtx-1080-ti-without-ai-cores/
it is wccftech after all so take the news with a huge grain of salt XD
Yep, on previous NVidia GPUs, they put a very conservative boost of around the same mark but easily boosting and holding ~1950Mhz out the box on some of the OC cards (and possibly ref cards)Boost is noted to be 1635 on the FE in OC mode, so it's possible they will reach 2GHz but I wouldn't count your chickens. At this point, it's anyone's guess.
