It was my Corsair Hx850 that needed to be changed, it was bought around 2009 IIRC.
A PSU is kinda divisive in opinions on what to buy.
What I mean is that there are those who frown upon buying one with a much larger margin than needed and then the others who like to buy a larger wattage supply believing that to be for the best.
I'm inclined to lean towards the larger than needed supply.
With that in mind my 6700k at 4.7ghz and the overclocked 1080Ti just manages to draw just over 400w at most, less than 35 Amps.
I do like the Hybrid mode on this Seasonic as it means when in use the fan does not come on, at least it hasn't so far even when using the max that my system draws.
just looked online at nvidia forums around the use of low powered psu's with gtx 1080ti's and nvidia's recommendations are a good quality 600w model with at least 45 amps on the 12v rail (Preferably +10% due to the power fluctuation (higher) properties of Silicon)
here's a link
https://forums.geforce.com/default/topic/1002514/question-about-running-a-1080-ti-with-a-small-psu/
