Hey Gibbo, apparently they fixed it with this you have in stock - 1 left!
>> https://www.overclockers.co.uk/thermal-grizzly-minus-pad-8-20x-120x-2-0-mm-th-019-tg.html
EDIT: What was said above, didn't see before I posted.
>> https://www.overclockers.co.uk/thermal-grizzly-minus-pad-8-20x-120x-2-0-mm-th-019-tg.htmlI used a 120x20x2mm strip of Thermal Grizzly "Minus Pad 8". I left each 20mm wide, which extends coverage to contact more of the retention plate for the small strip, and widens the coverage to cover the FETs I talked about before. Notice there is even a nice wide area built under the heatsink to accomodate this width -- I drew the rough size of the previous grey stock pad under it.
Link as netdps mentioned >> https://www.overclockers.co.uk/thermal-grizzly-minus-pad-8-20x-120x-3.0mm-th-029-tg.htmlBack to the main VRM bank! Here I used a 120x20x3mm strip of Thermal Grizzly "Minus Pad 8". I strongly recommend a 3mm pad here (as ridiculously thick as that is, it is required to make good contact).
