Pinnacle ridge is on 1.0.0.4 currently but the QVC list for 3200 ram is still just 10 productsSummit Ridge 1.0.0.4 is ancient isn't it? The latest is Pinnacle Ridge 1.0.0.2a or something.
Yeah, I think they are, it's 1.2V 2133MHz, but it's got a 3600MHz SPD setting as well.
Heads up for first wave Ryzen owners.
My 1800X is suffering degradation already after almost 18 months. Noticed that my PC was locking up in BF1 and BFV. Initially blamed the game and a setting (performance bias i had set recently) but turns out, after testing with realbench, memtest and Prime95 that I needed to bump up the vcore a couple of notches.
It had previously been sat at 40x101 @ 1.375v and rock solid for over a year.
Just a heads up, but I might just be unlucky.
What was your soc voltage?
1.1v
SOC @ 1.1v certainly wouldn't be any sort of issue. On the face of it, Vcore @ 1.375 shouldn't be an issue either. What level of LLC are you running ? Because running high levels of LLC can certainly cause damage, voltage pikes from high LLC levels on most CPU's tend do the most damage.
Indeed. Overall voltages were quite low all things considered. It's been a great chip!
LLC level 2 (on CH VI).
I'm considering just doing the segfault RMA![]()
I'll keep you postedhopefully it goes through okay.
Just for reference I have 1600X and 1700 builds at higher voltages for over a year and all is well still. Must be segfault![]()
You can certainly still RMA for segfault. No guarantee the chip you get back will be 4GHz capable at any voltage though, so it's a gamble!
mine dont even at silly volts it black screens on anything over 3.925True, though I do find it hard to believe that there's 1800X out there that can't do 4GHz.
well its probably a bad chip + terrible motherboard brand & software support (gaming 7)I imagine you must have got the worst chip, motherboard or missed something?
