Should more homes have air conditioning these days?
6 Jan 2013
Rollergirl
'Normal' conditions, not so much, but if I start gaming on my PC, that starts heating my room up, or the lamps for recording videos will do the same.
I know you can't abide criticism and have half the forum on ignore as a consequence, but seriously that is one stupid reason to have AC. It's literally like trying to cool a room with the radiator on. :p
25 Mar 2004
Fareham
AC and heating are only solutions to a problem that need not exist (or at least to a far less extent) if homes were built in a way to naturally stay temperate. For example heat exchange systems in a well sealed home with good insulation can keep temperatures reasonable all year round without wasting huge amounts of energy on heating or cooling (the heat given off by the people living in the house can be enough at times).
It just seems odd that we have all this technology available but loads of people still live in old draughty houses that they can't afford to heat, some new builds aren't always much better (last one I rented was freezing downstairs). We should able to keep a building at a constant (or pretty close) temperature rather than the extremes of too hot / too cold and the arguments over when to turn the heating on (do you set it for a couple of hours or leave it at a minimum temperature etc). Plus you have other downsides to AC / heating such as drying the air out and causing skin complaints.
Essentially I want to live in a cave. :p
My house has a heat recovery system (MVHR) but it's crap as far as I can tell and is a total waste of time. In the summer it helps not at all to keep temps down, in the winter it simply blows cold air into the house meaning I have to work harder to heat the house.
This on top of being noisy (the developer had it switch off at the fuse box when showing me around - whether intentionally or or not I can't really say). There are vents in all 3 bedrooms which give a constant background droning sound when the vent is in the open position. I have to close the one in the main bedroom so I could get to sleep properly.
The unit I have can't be switched off unless I do so at the fuse box to make matters worse, I can't even have it off overnight on a controllable schedule. I believe it's the Ventaxia Sentinel Kinetic B model: https://www.vent-axia.com/range/lo-carbon-sentinel-kinetic.
My understanding is the MVHR system is meant to push a certain volume of air to work at the designed capacity. At that calibrated level it was so noisy I thought I was on the deck of the starship enterprise when I flipped the fuse switch to the on position.
My old house had trickle vents in the windows, and extractors in the bathroom/kitchen (on 24/7 for moisture removal, but boosted when the lights were switched on). I had isolator switched though so I could disable them if I wanted to. The old one seemed to work better and cost a lot less to do. Presumably the developer does it to meet some kind of green energy accreditation.
18 Oct 2002
The land of milk & beans
9 Apr 2007
I've already got the heating on. The rooms without heating are averaging 18c, too cold. Rooms we use are kept at 20c all year round.
AC not worth it for the odd few days a year.
25 Mar 2004
Fareham
That's all you need.
OK, but I have maybe 4 rooms I use frequently enough that I would then need 4 fans minimum, I'd need to put them somewhere so that I could use them without them being in the way/access to power, and to keep on switching them on/off all the time depending upon what I was doing. I can't really sleep with a fan blowing at me either.
Split aircon is far better if done properly, and doesn't just move the hot air around the house. I don't know if you've tried living in a stupidly insulated new build house during a few months of heat like we've just had, but it's not been a lot of fun with or without fans. Frequently reaching 29-30c with no way to properly dump the heat, as opening windows doesn't even help unless there is a decent breeze outside.
You don't need 16c indoors at the height of summer for a home, but a small unit or two will take the edge off the higher temperatures. They can also heat as well if you get the ones that do air source heat pump functions.
21 Nov 2004
Spent most of the summer being woken up at 5AM by seagulls, magpies, neighbour's chickens etc due to my open window. I'm planning on installing a proper air con and ventilation system so that I can sleep undisturbed with nice cool, fresh air.
6 Jan 2013
Rollergirl
You could also consider manning up a bit... It's just a little period of discomfort during an unusual spell of hot weather.
25 Mar 2004
Fareham
I don't call 3-4 months of a 12 month year a little period of time.
Tell you what, go the whole winter without using heating, just man up a bit?
Meanwhile I'll look at booking in some AC installation so I don't spend all summer dying in the heat.
23 May 2006
I live in a chalet bungalow, i.e. bedroom in roof, was unbearable, split AC being installed as I nearly lost work through feeling so exhausted due to heat
Will get it done next month or so
